It is currently Mon Jul 21, 2025 10:25 am
PostPosted: Wed Jan 24, 2007 12:44 am
It arrived Monday. Last night I had a chance to get it assembled, not a lot to do but add the small diameter circle attachment and drop the 310 in. I will be cutting rosettes this weekend so Ill give a report then on how well it works.
What I can say now is that its built like a tank, to very tight tolerances. The 310 dropped right in, but was a perfect snug fit. The fine adjustment knob works great, as does the plunge took. Its a well built jig.
Here are a few images I took last night.
PostPosted: Wed Jan 24, 2007 1:07 am
Lance, what did that set you back? I forgot, is it from StewMac?
PostPosted: Wed Jan 24, 2007 1:42 am
Paul, its from Allied Lutherie, 249.50 for the base,
DIRECT LINK
and I found a PC310 for 149.00 at the Toolbarn...
LanceK39106.4059953704
PostPosted: Wed Jan 24, 2007 2:00 am
Very impressive base there Lance!It looks very sturdy
indeed.
PostPosted: Wed Jan 24, 2007 2:04 am
First name: Roger
Last Name: Labbe
[QUOTE=LanceK] not a lot to do but add the small diameter circle attachment and drop the 310 in.[/QUOTE] Could you expand on that? I see the attachment - does it come with the base by default or is it something extra you needed to order?
PostPosted: Wed Jan 24, 2007 2:26 am
The little attachment was 10.00, it moves the centering pin closer to the bit.
PostPosted: Wed Jan 24, 2007 2:51 am
First name: Larry
Last Name: Hawes
Nice looking jig. I've got a Bosch colt - any way to know if it will in that jig?
Thank You and Best To All
PostPosted: Wed Jan 24, 2007 3:00 am
I'm pretty sure its made just for the PC 310 and the Dremel. Two different models.
You can follow the link I posted above and see what is available, maybe even give Bishop a call, maybe he can do custom apps?
PostPosted: Wed Jan 24, 2007 4:29 am
Sturdy looking, PC probably cuts truer than the Dremel. Is it as heavy as it looks? Clinton
PostPosted: Wed Jan 24, 2007 4:38 am
Its hefty, not to much so, but enough to not bounce around when you turn it on. One thing I noticed imeadiatly was the 310 and how smooth it ran.
PostPosted: Wed Jan 24, 2007 5:18 am
I recently picked up a PC310 after throwing a cheap laminate router in the trash bin due to runout. It's SMOOOOOTH! Don't tell SWMBO!!!
Kurt
PostPosted: Wed Jan 24, 2007 5:26 am
and the other beauty of this thing is it PLUNGES.... that is a very nice feature.
PostPosted: Wed Jan 24, 2007 11:43 am
Lance...very nice setup!
Brad
Avon, OH
PostPosted: Wed Jan 24, 2007 2:07 pm
if the 310 base is as good as the dremel base it will be very good indeed. i have lusted after one since it was first announced but could never justify spending the $$$$$. then i lost out on an ebay auction where one went for $150
then i saw the microfence 310 base. has anyone laid hands or eyes on the this base for 310's and others. i have only seen the ad hype, and it looks very impressive, as does its price unfortunately, but i have not heard from anyone who has laid eyes or hands on one. does anyone have any first hand knowledge? crazymanmichael39106.9399537037
PostPosted: Wed Jan 24, 2007 2:14 pm
Wow Lance! That's a pretty slick looking jig!
Plunges and makes circles... Very nice!
PostPosted: Wed Jan 24, 2007 3:59 pm
I'm freak*** jealous!
Yup, very nice and slick set up!
